PanelClaw Debuts Sun Bear Ground Mount System
SOLAR TODAY
The Sun Bear penetrating ground-mount solution from PanelClaw offers simplified construction, including only four pre-assembled major components and no loose fasteners. Struts can be attached to any Sun Bear foundation type, allowing for a range of soil conditions without needing to change the above-the-ground racking design. Integrated turnbuckles allow installers to adjust the system directly in the field to accommodate uneven terrain, adapt to foundations and level the array for a smooth appearance. The telescoping rafters of the Sun Bear frame slide out into a locked, squared position in-field, speeding up the installation process.
panelclaw.com
