High-Temperature Paint for Solar Coatings
Tempil’s Pyromark 2500 paint is designed for high absorptivity/emissivity properties and long-lasting protection in solar and heat-transfer applications.
At maximum temperatures these paints do not blister, crack or peel. The paint demonstrates emissivity and absorptivity values of more than 0.95.
Tests show that these silicon-based coatings help prevent oxidation, corrosion and abrasion on mild steel, stainless steel, aluminum, inconel, aluminized steel and ceramics.
tempil.com
